- This topic is empty.
AuthorPosts
October 24, 2010 at 9:04 am #6485
Anonymous
Hi all
I have just replaced a second exhaust elbow on my B34(2000) , 19hp 2020 VP. There is elsewhere on this forum a convoluted story about how the problem of low power and revs was eventually traced to the elbow that was full of rock-hard carbon. It was replaced with a new one.
This time I went straight to the elbow and it was full of carbon again after 3 1/2 years.
My theory is that the saltwater, through heat exchanger, is pumped straight onto the hot exhaust pipe in the elbow and eventually punches a hole through it and then the elbow quickly fill with carbon. The performance of the motor fell off very quickly.
I think a stainless fabricator may be able to come up with a better solution that could be disassembled ocassionally to remove any carbon build up.
Has anyone else had a similat problem.
Greg
Tanami (B34)October 30, 2010 at 4:06 pm #8400Anonymous
Hi, have a look at the piece i did in Hints and Tips regarding my exhaust riser and see if its the same problem
Ed Holmes
October 30, 2010 at 11:06 pm #8401Anonymous
Hi Ed
Yes! I think it is the same problem.
On the 2020 the riser has a cone inside it so that the water from the heat exchanger is not squirted directly into the exahust. The water spreads around the cone and is then pulled into the exhaust flow by the exhaust pressure.My risers have been full with rock hard carbon deposits which have also got into the cone. I think it would be impossible to do any “rodding” inside the cone as it is a tight fit. I have heard of the soaking solution but I am doubtful that it would work on the rock hard carbon.
I am going to talk to a stainless steel fabricator to see it is may be worthwhile having something made where the other shell can screw off exposing the cone.
Will keep you informed.
Greg
AuthorPosts
- You must be logged in to reply to this topic.
