• This topic is empty.
Viewing 6 posts - 1 through 6 (of 6 total)
  • Author
    Posts
  • #6532
    Anonymous
      Didn’t get all the water out of the shower head last fall and the freezing cracked the plastic section that attaches to the hose. The head has no manufacure name on it only “Italy”. Does anyone know where a replacement might be secured? Maurice E. Cook
      #8568
      Anonymous
        Hi Maurice,
        In the UK the best place to buy them is Penguin Engineering (http://www.penguineng.com/contactpenguin.html). Call them on 44 23 9246 5607.
        Tell them the model and year of build and they will post you the shower head that you need.
        They are UK post but I’m sure they will post to the States.
        Regards
        Rick
        #8569
        Anonymous
          And as my brain works faster than my fingers I meant they are UK based, not UK post!
          Ho Hum, back to the medication.
          #8571
          Anonymous
            Rick, thanks so much. I got no help at all from the Bavaria dealer. Will contact Penguin. Maurice
            #9012
            Anonymous
              We had the same mishap our first winter. We know better now.
              The shower head has metal end pieces, with a plastic handle in the middle; the plastic part had split and squirted water when under pressure (i.e. when the pump ran). The metal part wasn’t affected.
              My fix was to remove the plastic component, then make up some epoxy glue (Araldite), and dribble it into (and around the inside the handle whilst it was still fluid. This re-lined the inner part of the handle with a new waterproof inner-skin
              No more leaks 🙂
              #9313
              Anonymous
                you can get them from force 4, its a stock item
              • The forum ‘I can’t find it :-(’ is closed to new topics and replies.
